How to stop a while loop ?
The program is running in a while loop and my frontpanel is waiting for a selection.
Pushing two buttons start subvis, but when I try to stop the While loop, it doesn`t work.
The main VI just doesn't stop.
The inner loops seem to continue.
Sorry the other questions and answers didn't help me. I know it's an easy proplem, but would anyone be so kind to help me?
Message 1 of 16
(5,232 Views)
All time that your 2 buttons "Enter" and "Button1" are false button Stop can't abort loop because you all time is founding in inner while loops. You must add checking of stop button also in inner loops for aborting.
Look changed VI.
Message 2 of 16
(5,232 Views)
Thanks for your quick answer.
But my labview program LabView 6.1 says "Latch function with a button doesn't fit with a local variable"
I can't run your program.
Message 3 of 16
(5,232 Views)
Click on your "Stop" button right click, select "mechanical action", select one of up row selections :"Switch until pressed" etc.
Message 4 of 16
(5,232 Views)
Nope is not working, non of the mechanical actions. Did you tried it by yourself?
I need an answer, how to start a while case inside a other while case.
This must be possible and shouldn't be that difficult.
Stupid me.
Message 5 of 16
(5,232 Views)
Message 6 of 16
(5,232 Views)
I press the STOP Button. Sometimes nothing happen, sometimes the two other dialog windows are poping up.
But the main VI doesn't stop.
Did it run on your system and stopped the VI?
Is it because the While loops are closing and the dataflow goes to the sequences and they are runing?
Message 7 of 16
(5,232 Views)
Change mechanical action of "Stop" to "Switch When Released" instead "Switch Until Released"
Message 8 of 16
(5,232 Views)
As I said before, all the mechanical actions doesn't work.
With "Switch When Released" the two windows pop up, and afterwards the Main VI is stopped. Not the result I want.
Beside that, the stop button stays dark grey afterwards, why is this?
Message 9 of 16
(5,232 Views)
OK. Please send me all vi's that you are using in main.vi I haven't 3 sub-vi's for checking all.
Message 10 of 16
(5,232 Views)
