How to split the string from character position.
What string do you actually get? You keep saying it's not working but have not posted your code or explained anything in detail. Silly to keep referencing a 'mid' function that you aren't using.
Message 11 of 17
(2,007 Views)
What have you done so far? You need to show us your code.
Your example is not correct.
mid("HelloWorld",5,2);
The 5th character is o and you should get "oW" from  "HelloWorld".
If you want to go back in the string, then the 2 should be a -2.
That should give you a "lo" ( "HelloWorld" ).
Message 12 of 17
(2,005 Views)
you have to play with the indexes obiously, atm start=0 and end=0 will result in one character
on another note:  you are clearly a novice with labview -- try read the documentation, use the help, the quick-drop, and search before posting .. google definately would have had an answer for you
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 13 of 17
(1,986 Views)
The Fallowing Vi is not working for me, couild you please tell how to make it.
But if i interchange 2 and 5 its works fine.
How to make it wokr without interchanging.
Message 14 of 17
(1,975 Views)
first: you took the example that someone two post later said not being "correct"
second: why do you have DBLs and not Numeric Contants???
third: have you read any documentation/help regarding either the datatypes or the substring-vi you are using?
fourth: post you pseudo-c-code for what you want to do, i suppose you have no idea 😞
Message 15 of 17
(1,960 Views)
Why are you trying to make things so complicated?  You only need a single String Subset.  It has 2 inputs for index of start and the length.  Just use both.
Message 16 of 17
(1,952 Views)
he said something about reverse .. when start > end
Message 17 of 17
(1,941 Views)
