How to split 1 channel waveform to 2 different waveform for analysis
Hi, im very new to labview and im just thinking how do i actually split a single waveform into 2 different waveform for analysis. for instance,for the attach image, i only want to take the compression zone while removing other image.
Secondly. how do i actually use labview to count the number of peak that exceed a certain level of voltage using labview. so for instance any peak that is below the voltage level is actually ignored.
(2,815 Views)
Hi skydew,
                  See the link below:-
                  http://forums.ni.com/t5/LabVIEW/How-can-I-split-a-waveform-into-chunks-at-each-sawtooth/m-p/1333524
Thanks as kudos only:)
(2,808 Views)
Thanks alot. 🙂 would look into it.
(2,802 Views)
