How to solve the problem of nested while loops which are supposed to take a fixed amount of time
Hi
The outer while loop in my code is to display notes being read from a file one line at a time and simualte them falling down a screen. I also came up with code that could take input of a number (fundamental frequency) and output a corresponding note.  This part was just to simulate the data that would come out of the DSP and get converted to a note. The next part I tried to do was the comparison. I want the comparison to work in such a way that I the element at the bototm of the screen is compared to the output note from the DSP and the code I wrote. For this I created a while loop. We will be receiving about 680 inputs from the DSP every second. I want the inner while loop to work in such a way that if a match is found between the note displayed at the bottom and the note played, the seond while loop should exit. However, if there isn't a match, the checking should continue until the time that there is a change in the last element of the display. All this need to be done without messing with the original 1 second interval of notes being displayed.
I thought the one 1000 ms input on the outer while loop would limit the amt of time the inner while loop could take but that is not the case. Any suggestions?
-Karan
(2,705 Views)
Karan:
It looks like your question went unanswered. Please let me know if you still require assistance.
Rudi N.
(2,581 Views)
