How to simulate a DAQ device and use it for testing applications without hardware???
                        how do i simulate a DAQ device in MAX and use it for testing applications without  hardware???
If my application requires inputs from external hardware to proceed how can I simulate a DAQ device in LabVEIW?
i need to simulate several Digital inputs and Outputs to test the software. currently i dont have the hardware and DAQ device here
please reply with your valuable suggestions.
many thanks in advance
RENN
Kudos always welcome for helpful posts 🙂
(5,178 Views)
simulate traditional DAQ device is not working in Measurements and Automation Explorer..? how can i create one
i need to create PCI 6014 and use it in Labview 7.1
(5,172 Views)
HI,
   To simulate the data go to MAX>right click on Devices and Interfaces>NI-DAQmx simulated device>select your devices and enter ok.Hope this helps you
(5,167 Views)
i need to simulate a Traditional DAQ device..its not working
(5,165 Views)
Accepted by topic author RENN
      There is no option to simulate traditional device.You need hardware for that so i would suggest to simulate a PXI device which has similar configuration to PCI-6014 and to do a small modification to your application..
(5,152 Views)
