How to show the Str() value in Hex
HI,
I'm using the following command in a vi and would like to see an Hex presentation.
                 "My number is  "  + str(number1 + number2)
The parameters number1 and number2 are in Hex but the result of str is the value in decimal.
Is there a way to force it to show in Hex?
I have tried  str((number1 + number2), "%$.13f")   but it didn't work.  I still get a value in decimal.
(I don't' really understand the meaning of this formatting.  I saw it somewhere and thought it might do the job)
Can anybody give an explanation to this formatting?
Rafi
(2,809 Views)
Accepted by topic author Rafi2003
The format you want is %x. The format specifiers are specified in the LabVIEW Help.
Format Specifier Syntax
Format Specifiers Syntax Elements
(2,807 Views)
