How to show points in a waveform- or x/y- graph/chart
is it possible to add points to a waveform graph (or any other applicaple object which visualises plots)?
What I want to do is to clearly mark all out of range data points of a waveform after having done the limit testing. It is rather easy to get the data of the points but it was impossible to add them to the same graph than waveforms. Even after converting the waveform to xy-pairs (what a horrible waste of CPU-time) the arrays were not compatible.
What is the best approach to that problem?
Gruß,
Bluegraf
(2,995 Views)
Look at this example file.
C:\Program Files\National Instruments\LabVIEW 7.0\examples\measure\maxmpl.llb\Limit Testing Measurement.vi
If you aren't using waveforms for your data, I have a hacked up version of the limit testing vi's that work on array data.
Message Edited by unclebump on 06-21-2006 04:56 AM
(2,994 Views)
Hi unclebump,
Thanks, that was what I was looking for... the NaN was the trick.
The only point I'm still missing is the fact, that it is not possible to define which plot to print on top without re-arranging the input array. It would be a bit more comfortable to have this in the properties (Little hint towards NI 😉 ).
Gruß,
Bluegraf
(2,983 Views)
