How to show digital display of a Slide Control/indicator in LabVIEW NXG 2.1?
In LabVIEW, we can do a right-click then select Visible Items -- Digital Display. In LabVIEW NXG, if you right click, select "Visible Parts", there is only "Label" you can select. I didn't see anything in the configuration pane either. Does anyone know?
(3,053 Views)
Not added yet, but, you can work around it.  I added an indicator and just hid the label and used the slide control as the value for the indicator.  Should look and function the same.
Ben Johnson
ʕง•ᴥ•ʔง
(3,023 Views)
OK. Thank you for your confirmation. It will be nice to see all the good features in LabVIEW be added to NXG...
(3,019 Views)
