How to show arrays in graph using x and y values?
i have two arrays (frequency and voltage).
How can i put these into a graph so that frequency is x-scale and voltage y-scale?
I tried to use the XY Graph and input the the two arrays with BuildArray but this is not working.
How to do this?
(2,848 Views)
Accepted by topic author OnlyOne
After using "Bundle" instead of "BuildArray" its working fine.
(2,838 Views)
This is made clear when you have Context Help turned on. You should always have this on.
(2,814 Views)
