How to share LabVIEW settings?
Is it possible to configure mutliple PC's with the same configuration options of LabVIEW.
I am in a very large company and it is important that color and style is enforced.
I want the abality to hand somebody a file or set of files and they would have the exact same configuration in their LabVIEW program. For example everything found under Tools>>Options, the color palette found on the Tools Palette, and common templetes with custom glyphs for the icon editor.
It is very fustrating when working in a repository such as SVN and the shared code differes from developer to developer. (we have many people working out of a project).
The LabVIEW.ini doesn't seem to cary all of the Tools>>Options and there seems to be more to this than just copying the glyphs folder in the datapath.
How can I configure LabVIEW to work better in a large application enviroment where it is expected that multiple people will be using LabVIEW?
Engineering - The art of applied creativity  ~Theo Sutton
(2,428 Views)
Which settings aren't in labview.ini? I'm fairly certain that sharing that file should be sufficient.
(2,415 Views)
