How to set the x y scale of the plot
Their display value may not be the same as the real value.
Can I make it without changing the original data.
Also it need to follow the change when zoom in.
Any suggestion, thanks.
(3,192 Views)
How to set the X Y scale for a plot?
You can set the scale via property node. Right click the plot and select create property node and choose x scale and y scale.
Could you please explain a bit more? I was not clear with your words. Maybe better with a picture.
Mathan
(3,188 Views)
For example, the real data value is about 0~255, but I need to display them as 0~20M.
Any suggestion?
(3,178 Views)
Accepted by topic author alex.
You can use the scaling factors (available on the scale properties). These can be set programmatically (using property nodes) or by right-clicking the graph > Properties > Scales.
Edit the "Multiplier" to get the desired result.
Hope this helps.
Message Edited by dan_u on 03-17-2010 10:44 AM
(3,171 Views)
