How to set system priority
Hi NG,
Is it possible to choose the priority-level with wich a
labview-application is started on a win XP system? I´ve only found
something about setting priority-levels between different VIs. But what
i need is a higher priority for a hole application, without setting it
manually in the win XP taskmanager each time i start this application.
Thanks in advance
Klaus Finken
(3,263 Views)
Hello Klaus
For a Labview application, perhaps you can get help and a example in this link:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000A2970000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTION_0=programmatically+set+priority&USEARCHCONTEXT_QUESTION_S=0
Hope this helps you
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,263 Views)
Check this article published in LTR
http://www.ltrpub.com/LVResources/tips/tip_v10n1/tip_v10n1.htm
Naresh
(3,263 Views)
