How to set "VISA Read" as a event source?
I want to made the VISA Read as one of the event source.
For instance,  whenever the "VISA Read" read one byte, it can creat a event, so the event can process it.
How to realize it? Thank you.
Message 1 of 13
(4,256 Views)
Hi
You can use dynamic events. Create a new dynamic event, register it at the event structure and just raise an event if you get data from the serial port.
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 13
(4,252 Views)
I had tried it ,but unsuccess.
I have no ideas of using Creat User Event & VISA Read, they seem to can't connect together.
Can you give me more tips.
Message 3 of 13
(4,247 Views)
Could you post any code? Or maybe a picture of it?
Using LV8.0
Message 4 of 13
(4,245 Views)
Attached  is my code.
Thanks for your help!
Message 5 of 13
(4,242 Views)
Here is a possible solution. I'd suggest you to have a look at the LV manual, to get more into it.
Using LV8.0
Message 6 of 13
(4,234 Views)
hi there
please try the attached vi (not testet cause i don't have any serial device at hand).
it uses a string indicator as the data buffer. if there is new data the vi sets the "Val(Sgnl)" - property of the control which itself raises the "value changed" - event. i don't see a possibility to connect user events and VISA. there are the VISA - events (see the VISA advanced palette, but they also can't be connected to a event structure)
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 7 of 13
(4,235 Views)
Of course there is the possibility to use user events, but for me it just makes sense, if the event needs to be raised from other vis and if I use a state-machine. I know use it really often. For instance if I have to poll for a button to be pressed, I have a vi that polls and raises the event if the button is pressed. I than catch it in the event structure, log some information and enqueue an element into the queue of the state machine, which then retrieves it and executes the corresponding case. The necessary vi to raise an event is the "Generate User Event" vi, which is located in the event palette.
Using LV8.0
Message 8 of 13
(4,230 Views)
Thank you all of you!
Message 9 of 13
(4,223 Views)
Thanks, all of you!
Message 10 of 13
(4,223 Views)
