How to set property nodes for each of the multiple y-axes?
In Labview 6i, I have set up multiple y-axes on an xy graph. I want to change certain properties of each of the 2 y-axes independently. I believe I can do this using "property node".
However, after I have created a property node for the xy graph, I realised that there is only 1 y-axis selectable from the list of properties. How can I set the property of the other y-axis then?
Thanks for the help!
(3,155 Views)
I believe there is a property called "active graph"... this allows you to
select the active graph to apply the property changes to...
Later...
meng118230 wrote in message
news:50650000000800000093570000-1027480788000@exchange.ni.com...
(3,155 Views)
In LabVIEW 6.x, the property is called Active Y Scale.
Randy Hoskin
http://www.ni.com/ask
(3,155 Views)
