How to set position of DLL for .net-refnum?
i have a .Net-dll which is inserted in my vi as a .net-refnum.
For this i inserted a  .net-refnum and then righclick and then "Select .Net-class" + Browse.
Then i browse to my dll and select the class in it.
The question is now: How can i set the position/path of this DLL?
Currently the DLL is in C:\files, but when i rename the directory to c:\data then the DLL is not found.
One solution would be to set a search path to the directory, but i want to set the path manually via parameters.
Is this possible?
Thx
Message 1 of 8
(3,520 Views)
Hi OnlyOne,
can you show what you mean, please?
Try to help.
Mike
Message Edited by MikeS81 on 01-28-2009 04:52 PM
Message 2 of 8
(3,518 Views)
Perhaps the attachment makes it clearer.
thx for your help
Message 3 of 8
(3,513 Views)
When you reference a .NET assembly and save the VI, the path to the assembly gets saved with the VI. If you rename the directory then obviously LabVIEW won't be able to find it. Why would you think it would be able to? You can either keep the assembly in the same directory as the VI, or install the assembly into the GAC. See How the Runtime Locates Assemblies.
Message 4 of 8
(3,495 Views)
I dont think labview is able to find it.
Thats why i ask how i can sepecify the path to the reference.
When i can pass the pass then LV knows where to search.
Message 5 of 8
(3,476 Views)
If the path to the assembly was saved with the VI and you remove the directory, then how is LabVIEW supposed to be able to find the new location "automatically"? Please read this document: How LabVIEW Locates .NET Assemblies. You will need to work within these constraints.
Message 6 of 8
(3,473 Views)
Do you know where is the position of the GAC in Windows XP?
Thx
Message 7 of 8
(3,470 Views)
Normally it's C:\Windows\Assembly. However, you cannot simply copy an assembly into the GAC. First, it must be a strongly named assembly. Then, you either have to use gacutil, or the development environment to install the assembly. See here: Working with Assemblies and the Global Assembly Cache.
Message 8 of 8
(3,452 Views)
