How to set Cluster size programatically
Is there a way to set the size of a cluster programatically?
Marce
(3,842 Views)
I came up with an alternative for the fact that the cluster bounds property is not writeable. It came out quite elegant. Hope it's what you are looking for.
aartjan
(3,839 Views)
Aartjan :
Nice trick, I love it !
CC
Chilly Charly    (aka CC)
(3,827 Views)
I am adding this to my user library as a merge vi, so the refnum, subvi and cluster with two string controls are always together. Very useful. If you make sure that the string controls are in position 1 and 2, you can omit the piece of code that searches the correct refnums (the while loopin the subvi). You can also replace the invisible controls with controls you are actually using in your cluster.
aartjan
(3,824 Views)
Hi Aartjan !
Here is another version of your idea. No string ! And another trick...
CC
(3,816 Views)
As a matter of fact much more elagant then mine. Stars for you, CC.
aartjan
(3,814 Views)
