How to sent/recieve simple USB commands?
Before I start. I've been reading om the internet (USB tutorials, nuggets, etc.) for the last 2 days to get this,
but it is really confusing and I still have no idea how to do this. So I'm asking for your help.
I setup a custom USB device in MAX.
I need to sent this command:    0x2 M 1 0x3
Were 0x2 defines the start and 0x3 defines the end of the command.
I think I have to use a control transfer, but I do not understand what to use at the Index, Value, Request Value,
Request and Length inputs. I also do not understand how to sent Hex, Dec and ASCII at the same time.
Do I need to convert these values?
I would really appreciate some example code. Can I use the VISA commands?
Kudos will be given, thank you in advance Robot Happy
The Enrichment Center is required to remind you that you will be baked, and then there will be cake.
(7,563 Views)
Hi!
Maybe this can be useful:
(it's about VISA communication with USB devices)
http://zone.ni.com/devzone/cda/tut/p/id/4478
Marco
(7,547 Views)
Accepted by topic author SectorEffector
I am not sure about the Index, Value, Request Value,
But about sending your comand....
I assume the space before the "M" and the space after the "1" is not needed,
but the space between the "M" and the "1" is needed
Omar
(7,521 Views)
