How to select Device ID by name
Greetings All
I'm trying to have my device ID name show up on the front panel (like in the Configure Play Waveform vi)  instead of having to select just numbers. Is this possible?
Tia
(5,708 Views)
Take a look at this message thread.  It looks like it gives you a way to identify the sound devices on your PC.  Once you run this to get the identifying information, you could populate a ring control with that info, then proceed with the program that you have now.
(5,692 Views)
