How to search through an excel spreadsheet for a number based on restrictions that you input as a user and print them out?
Hi there guys
I'm trying to write a labview program and i'm new to the program. I need the program done asap. First the user inputs the row number and then based on the row number it opens and reads an excel spreadsheet file which is just a table and it outputs the numbers corresponding to the column I ask for. How do I go about doing that? I saved the file as a .lvm so Labview could read it. Its a project for school and I have no idea how to start it. Any help would be greatly appreciated.
Thanks guys a lot
(3,467 Views)
the data that is in the spreadsheet is numbers
(3,466 Views)
Ummm... what file did you save as .lvm, and what does this have to do with an Excel file? To read/write Excel files you need to use ActiveX. There are a couple of shipping examples on how to do this in LabVIEW. Plus, this has been asked like a zillion times, so there's tons of examples in this forum if you just do a search. Plus, there's an Excel thread that has lots more examples.
(3,448 Views)
Cant find an example that you could input the row and column and get the corresponding integer for the parameters
(3,416 Views)
This might help: http://sine.ni.com/devzone/cda/epd/p/id/3177
Jeremy_B
(3,414 Views)
Hi Jeremy
what I need exactly is to input the row and then it'll move across the row until it hits the right column name I ask for and input the integer that is in there.
Thanks a lot for the help
(3,402 Views)
Use the Find command (example) to search the row that contains the columns. This will return a range. From the range you can get the column. Now, since you have a row and column, you can just use the part of the code provided in the previous example to get the value of the cell at the specified row and column.
(3,377 Views)
