How to search and parse a binary file?
I need to search binary files for specific data messages.  These messages begin with "11111111" then follow with some more 8 bit words, one of which defines the length of the following data bits.  I am experienced with LabView but not with using binary files.  There may be several of these complete "messages" within a single data file.  How would I create a simple reading VI for this?
Appreciate the help!
(5,687 Views)
This 11111111 is a sequence that looks like an integer number of bytes (1 to 8), depending on data format you have written them.
Convert 11111111 to string (1 to 8 elements), read binary data from file into string, search this pattern in read data, format data after pattern as needed. If the file is too large, you can read portions of file.
If this file is a bit sequence and pattern has non-integer byte offset, it is more complicated.
LabVIEW stores boolean arrays 1 byte per element so it does not make sence to work with true bit patterns. I would say - read data as u8, convert each one into 8 bits thenconvert bits into strings (1 string byte per original bit) and search string as previously.
(5,677 Views)
That sounds promising.  Could you send a picture of how I would create that in Labview?  Or the VI?
Thanks!
(5,667 Views)
What part is not clear?
Work with file:
Open file -> [Set File position  ->] Read from binary file -> Close file
Make pattern string from bit array:
Boolean array to number -> build array -> byte array to string
Work with string:
Search string, string subset (or match pattern)
(5,656 Views)
You need to be significantly more clear.
"What is "11111111"?
Is it a sequence of 8 bytes, each containing a decimal U8 value of  49 (ASCII for "1") or is it a single byte corresponging to a value of 255?
Can you attach a simple file for testing?
(5,628 Views)
I don't have an example file with me from this pc.  The value of all ones is the bits (0 or 1) which are set to 8 "1"s in a row to signify new data follows.
(5,545 Views)
  • OK, unless the file is gigantic, read the entire contents into a raw string (e.g. don't convert EOL, of course!). Then you can use string functions to look for patterns.
  • You could even create a 1D array of strings each containing a dataset between delimiters by using "scan strings for tokens" in a loop and using 0xFF as the only delimiter.
  • Alternatively you could read it as a U8 array, then use search array to search for a value of 255.
(5,539 Views)
