How to save string to in excel file with time stamp
Hello!
I just stuck on saving string in excel file with time stamp.
please see attached file, data is saved in excel as number instead of actual string.
need help on this.
Regards
asif
(1,757 Views)
Hi asif,
you save a timestamp value to your file and you get a (numeric) timestamp value in Excel - what's wrong with this?
Btw. it most often is easier not to use ExpressVIs…
(1,730 Views)
thanks for your replay
i want to save string from string control.
when i write any string, it should save in file with date and time.
thanks
asif
(1,726 Views)
Hi asif,
use WriteDelimitedFile instead of those ExpressVIs to gain full control over file formatting…
(1,724 Views)
can we set header in file...
thanks
asif
(1,710 Views)
Hi asif,
Yes, sure!
You can write anything you want to a file: you juts need to implement that in your VI…
(1,695 Views)
