How to save several measurement into one file?
Hellow!
I have a TKTDS read waveform.Vi in a for loop,i need to save the data in a file,but every time i was asked to save to a new file,it is not convinent,so how to save all the measurement in one file instead of several file? thanks!
(2,921 Views)
How are you writing to the file?
(Assuming you are using one of the high-level File I/O VIs.) Make sure to keep the current filename in a shift register. If the file path is empty, you'll always get a dialog. Also wire a "true" to the "append?" terminal so the data is added to the end of the current file.
To save resources, you should probably use low-leve File I/O. Open the file for writing once outside the loop, then keep writing to it inside the loop. Close the file outside the loop when the VI stops.
(2,913 Views)
I use "write spreadsheet to file.vi" what 's low level write file?can you give me a example? thanks!
(2,909 Views)
Have a look at e.g. the example "Write to text file" that ships with LabVIEW. You can find it using the example browser.
(2,901 Views)
Please find attached Example VI for your reference.
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,897 Views)
