How to save data from sbRIO9651?
Hi, everyone!
I am trying to catch a data from I/O using SPI interface and sbRIO board, but I have the problem with putting data inside array. Everything works fine until I add array with indicator (Saved Array, marked with red line), for actually see inside array.
mainmain
Then I get errors, but all my arrays have fixed and the same size and type of data, so I don't understand why I get errors.
errorserrors
So, can someone tell me how to save all the data to table or array, which I can save as Excel file for further processing? Is there any other more simple way to do this?
(1,117 Views)
Accepted by topic author Zhargal
The Error Message explains the Error exactly.  You have an Array (of some size) on a Shift Register, and change the Array size by passing the Wire through an "Insert into Array" (which changes the array size!).  You should use "Replace Subset" (or use a DVR with a pre-allocated Array).
(1,105 Views)
Thank you so much for help! I just started to be familiar with Labview 😅 Thanks again, I am very appreciated
(1,075 Views)
