How to save data along configuration in one file
I acquire waveforms and images and need to save the raw data with their nested acquisition settings. Until now I used tdms and saved the settings as json string in a tdms parameter. Opening those files again works well as long as my application's settings cluster doesnt change.
I like to have configuration and data in one file. Any suggestions on how to achieve this more robustly regarding changing settings cluster?
Actor Framework
(1,846 Views)
Hi Quiztus,
I still would use TDMS files, but instead of converting your (typedefined) clusters to JSON strings I would store the cluster elements as individual properties of the TDMS group/channel.
It's a little more overhead while writing/reading, but prevents all problems with your cluster typedefinitions: you can read all properties and use default values for non-existing items…
(1,837 Views)
I followed your advice and it looks promising. For the sake of completeness I upload my working snippet.
Actor Framework
(1,800 Views)
