How to save a 29.97 fps AVI file?
I'd like to encode and save an IMAQ video stream (usually a DV cam) to an AVI file.  But the 'IMAQ AVI Create' vi only accepts an integer for 'Frames per Second' while DV video is 29.97 fps.  This results in a playback speed that differs from the original source.  Is there any workaround for this?  Thanks.
-Joe
(3,046 Views)
hi Joe,
I do not see any workaround to change the FPS of an AVI file created by IMAQ AVI Create to a non integer value. I understand that the spec for your DV camera is 29.97 FPS. Is this number the same as the actual FPS you are capturing at? I ask this question because there are similar form posts on this aspect.
http://forums.ni.com/t5/Machine-Vision/Record-avi-and-FPS-mismatch/m-p/1215791?requireLogin=False
<Joel Khan | Applications Engineering | National Instruments | Rice University BSEE>
(3,014 Views)
Yes, the DV spec is 29.97fps, and I am acquiring at 29.97fps.  I don't believe it is possible to capture from a DV-cam at an other frame rate.
(3,002 Views)
