How to running apogee U10 Camera in labview
I am new to labview and trying to setup an Apogee U10 camera to work with labview. The vi provided with the camera can only detect the camera. Are there vis examples that can help also get images etc with this camera. If not, what would be the best way to set this up.
Priam
(3,354 Views)
(3,336 Views)
Right now (from the attached example code) it seems that the VIs with the camera might just be calling ActiveX to the camera's driver, and then manipulating the data.
If you want the raw data in LabVIEW, you will have to use an NI driver (IMAQdx for usb) to bring it into LabVIEW. This driver will ship with Vision Acquisition Software. And as long as the usb camera is DirectShow compliant, it will work with our drivers in LabVIEW.
Hope this helps!
Chris
Chris Van Horn
(3,310 Views)
