How to run two vi's simultaneously?
I am relatively new to labview, so I am not expert enough to figure this
out,... yet. I am running a test setup using several pieces of test
equipment. Therefore, the screen is pretty busy as it is. At certain
points in the test, I want to click on a button that calls up a spectrum
analyzer, which takes a snapshot of the data, then close. The problem is
that when I "click" the call spectrum analyzer button, the other test
equipment stops taking data. I then pretty much have to restart the whole
shebang. Any help would be appreciated.
thanks in advance,
eric
(3,101 Views)
Use VI server and set the caller not to wait for the called VI to finish.
Look at VI server examples.
"llertnac cire" wrote in message
news:8g0rpe$5do$1@hammer.msfc.nasa.gov...
> thanks in ad
vance,
> eric
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 80,000 Newsgroups - 16 Different Servers! =-----
(3,101 Views)
I've done something similar in the past and used the following
available vi's Get Instrument State.vi with Preload Instrument.vi, Run
Instrument.vi, Open Panel.vi and finally Close Panel.vi
Its been awhile so I don't remeber exactly how I set them up.
In article <8g0rpe$5do$1@hammer.msfc.nasa.gov>,
this
spectrum
problem is
ther test
whole
> thanks in advance,
> eric
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,101 Views)
