How to run several adb commands with System Exec.VI
How to run several adb commands with System Exec.VI. Tt is ok when run one adb commadn. My code is showed below.Please help me .Thanks
Message 1 of 8
(6,067 Views)
Message 2 of 8
(6,060 Views)
There are two ways to do that:
1) create a batch file with these commands and start that from System Exec.
2) use 3 seperate System Exec calls, one for each command.
Rolf Kalbermatter  My Blog
Message 3 of 8
(6,032 Views)
Could you give me a code example by using the .bat to run commands? i have tried a run System Exec with .bat ,but it is Wrong
Message 4 of 8
(6,004 Views)
use "cmd /c build.bat", System Exec is not a dos command shell but only a process launch. As such it needs to get an executable as parameter that can be instantiated by Windows. cmd is the DOS command line interpreter.
Message 5 of 8
(5,978 Views)
Possibly a silly question, but are you able to run multiple commands by seperating them with an &?
http://digital.ni.com/public.nsf/allkb/4AF9BB1ECC5DD0308625722E00834050
I think there was a bug report on the forums recently where this wasn't working on Windows 10 for whatever reason but that is how I normally see this done.
Message 6 of 8
(5,965 Views)
It is ok to run .bat with System Exec.vi Thanks for your help
Message 7 of 8
(5,951 Views)
yes,Its a silly question。haha, now It's done. Thanks for your help.
Message 8 of 8
(5,941 Views)
