How to run Multiple Same Vi in Parallel?
I have a main VI, and a second VI
in the main VI, i will put a button, Add new OVEN, when the user press it, the second Vi will run and Capture the Oven Datas.
When i click again this button, Another Windows of the Second VI will start and Capture the Second Oven Datas...
ect...
I dont know how to make my VI run Many Times.. as in parallel mode... Same Vi running.. and not connected with the Other one...
Thank you all for you help,
//The Best Way to Predict The Future is To Invent it//
~~~~~~~~~~~~~~~~~~Looking for a LABVIEW JOB (In EUROPE)>~~~~~~~~~~~~~~~~~~
**The Best Way To Predict**The**Future Is To Invent It**
Salimos - View my most interesting photos on Flickriver
Message 1 of 14
(11,587 Views)
Good morning
Check example in: C:\Program Files\National Instruments\LabVIEW 8.5\examples\viserver\runvi.llb
Message 2 of 14
(11,578 Views)
I am trying to do this.. without using the TCP server.. cause i will use it inside my VI,
after putting In the option Field in the OPEN VI Reference the Value (8..  As an reentrant VI..)
I am having the Following Error
The fonction Open VI cannot prepare an (Non-reentrent VI for an Reentrant execution)..
how can i change my VI to an Reentrant one??
Thank you Very much for ur Valuable help,
Best Regards,
Message 3 of 14
(11,569 Views)
VI set reentrant in properties of VI in Execution section.
Message 4 of 14
(11,556 Views)
Accepted by topic author salimo
check:
http://zone.ni.com/reference/en-XX/help/371361A-01/lvconcepts/suggestions_for_exec/#Simultaneously_Calling_SubVIs_from_Multiple_Places
Message 5 of 14
(11,552 Views)
Thank you for help,
My Vi is finaly Working,
Have a good end of day 😉
Message 6 of 14
(11,518 Views)
Thank you.
I finished in this moment 😉
Message 7 of 14
(11,506 Views)
Hi, I am practicing the same settings on the reentrant flag of the subVI, but yet it doesn't work! The url link on the thread which is cosidered the solution is no longer available! please advice.
Siamak
Message 8 of 14
(11,311 Views)
Here are a couple other articles.  What do you mean it doesn't work?  Does your main VI call the subVI multiple times, but only one instance is executed at a time?  Some other problem?
http://decibel.ni.com/content/docs/DOC-5598
http://digital.ni.com/public.nsf/allkb/98847B4E4C715E6D86256C59006B57CC
Message 9 of 14
(11,302 Views)
Calling reference to the subVI is in the loop (LoopA) (with different parameters), and there is a main loop (LoopB) in the subVI. LoopA does not proceed after the first iteration. When I stop the subVI loop (LoopB) from the main VI using a shared variable, then LoopA grows up.
I will take a look into the links you forwarded, and will do more tests.
Cheers,
Siamak
Message 10 of 14
(11,288 Views)
