How to run Labview exectuable on remote machine?
I am trying to use VI Server to launch a built Labview application (.exe) residing on a remote PC from a CRIO.  I need to run this .exe programmatically and I would like to do this with only the LV Run-Time Engine installed on the remote PC (Windows XP).  I am currently able to do this successfully, but only if I have the LV Development Enviroment splash screen is open on teh remote PC.  I assume this has somehting to do with the LV VI Server not running when the LV DE is closed.
I have also tried to build a dummy LV application that runs on the remote machine indefinitely (infinite while loop) hoping this would initiate the VI Server but it doesn't seem to work either, I get Error 63.
Anyone done this before?
Dan
(3,195 Views)
Have a look at this; it should answer your question:
Error 63 Using VI Server to Launch VI on Remote Machine
If you have any other questions, be sure to post back.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,187 Views)
Thanks, I've seen this one already.  I will be using a CRIO as my host so I believe ActiveX cannot be used to launch Labview on the remote PC.
I have been troubleshooting this issue bu using a PC (Win XP) for my host and client.  I have managed to get a Labview application to run as a Windows service on my remote PC and this application runs an inifinte while loop.  But even with this application running I receive Error 66 while trying to open an application reference to a VI on the client PC form the host PC.  Everyhting works fine if I have the LV splash screen open on the remote machine though.
(3,179 Views)
I finally got this to work!
I had enabled TCP/IP for VI Server Conifg uusing the Tools-Options menu from the project menu.  Instead, I have enabled TCP/IP for VI Server from right-click on My Computer (in the project tree) - Properties. (This also required disableing from Tools-Options).
I read another post discussing the difference between these settings locations but I need to review it...something do with the Main Instance vs. windows application instance??
Now to test with my CRIO
Dan
(3,167 Views)
