Using Linux, I load the LV6 Runtime engine and my application from a
CD with no problem. Just put a symbolic link in /usr/lib and point it
at the CD version of LVRTE. I don't know that Windows supports
symbolic links however.
As for installing the LVRTE in Windows, it is not necessary to use
the NI LVRTE installer. I supply an application to users (using InstallShield)
and simply install all the files in c:\Program Files\National Instruments\
shared\6.0\..... to the users C directory. Works fine with no registry
additions. Maybe you could temporarily install your app and LVRTE to
hard disk and delete it when you were done?
Alan Brause
"Darren" wrote in message
news:506500000005000000403D0000-993342863000@exchange.ni.com...
> Hello,
> You didn
't mention which "error message" you receive when you try to
> run the application from your CD. If you only have the runtime engine
> (lvrt.dll) on the CD and not installed on the computer, this probably
> won't work. The reason is that the LabVIEW Runtime Engine (for
> version 6.0 and later) creates some Windows registry entries when it
> is installed...I don't believe the 5.1 run-time engine did this.
> These registry entries are necessary in LabVIEW 6.0 for various
> reasons, all related to new features in LabVIEW 6.0.
> So to my knowledge, if you want to run an LabVIEW 6.0 executable on
> any computer, that computer will require the LabVIEW Runtime Engine to
> be installed.
> I hope this answer makes sense. Let me know if you need anything
> else. If you continue to have concerns about this, it would help if
> you told me the specific error message you receive.
> Have a nice day.
> Sincerely,
> Darren N.
> NI Applications Engineer
