08-17-2007 10:16 AM
08-17-2007 10:21 AM
08-17-2007 11:09 AM
08-20-2007 04:01 PM
Hi Mariachi,
I believe your overall project will be to collect data from your USB-6210 on multiple lines and save this to a file. Photon Dan is correct in the reason why you cannot use multiple tasks – because of the multiplexor, only one AI task can be run at a time. I would suggest putting all lines into one task and program, therefore eliminating the error, the need for multiple VI’s, and writing all data to a file at once. If you have further questions, I would ask that you post more detail about how you are collecting data (LabVIEW? SignalExpress? Etc) and your program. Unless you are connecting to other computers, you will not need to use VI Server, TCP, etc.
08-21-2007 07:34 AM
