How to round mathematical (not IEEE)
i have a number that should be rounded to the next integer.
I found that there is a IEEE... that described what to do for rounding.
But the mathematic-rounding is different.
The problem is only a x.5 values (1.5 / 2.5 / 3.5 / 4.5).
Labview is rounding to the next even integer - but the correct mathematical way is to round it always up if .5.
How can i do this in Labview?
Thanks for help
Message 1 of 10
(4,476 Views)
The reason you need IEEE for rounding is that there is no real representation for x.5 in floating point.  You basically always get x.5 +/- epsilon.  If it really matters, you could shift your numbers by machine epsilon.
Message 2 of 10
(4,470 Views)
Hi Taki,
there is a "real" representation of 0.5 in a floating point mantissa - as it is the same as 1/2 you really only need one bit of accuracy for this...
@OnlyOne:
If you really need to round always upwards:
(Any problems because of sign(x) are up to you...)
Message 3 of 10
(4,466 Views)
Thanks for help
Hi OnlyOne,
It is standard practice to round to the nearest even value when rounding with a 0.5 decimal place, although that's contrary to what I was taught in school! I recently read about this operation in Engineering Mathematics by K.A Stroud, so I'm unsure about whether or not this applies just to engineering. However, I've managed to indirectly derive the functionality you want through this VI below:
This method takes away 0.49 from the input double and uses the Round to Positive Infinity VI to round the input values according to your requirements.
I hope that you find this helpful; it'd be nice to find out whether or not this gives you the precision in your values that you're wishing for as well as if we need to find a better implementation!
Alex Thomas, University of Manchester School of EEE LabVIEW Ambassador (CLAD)
Message 4 of 10
(4,464 Views)
hehe, currently i do the same by + 0.1 🙂
I thought there is also a lv-function to round correct in school-style.
Message 5 of 10
(4,457 Views)
Hi OnlyOne,
"to round correct in school-style."
The problem is: school style is not the same as correct rounding Smiley Wink
And there were reasons to define bankers' rounding in IEEE754 standard!
Message 6 of 10
(4,453 Views)
But when someone writes 2.5 on paper then it is really a 2.5 and not any epsilon values behind it.
Message 7 of 10
(4,446 Views)
Hi OnlyOne,
when someone write 2.5 in a computer spreadsheet someone also gets 2.5! (See above.)
The problem starts with any fraction that is not representable by multiples of two!
"But when someone writes ... on paper"
When someone writes on paper he isn't aware of problems arising from rounding errors inherent to number representation on modern computers...
Message 8 of 10
(4,436 Views)
@GerdW wrote:
Hi Taki,
Indeed, you are right.  Too early in the morning for me to suppress my normal FP accuracy reflex.  🙂
Sorry about the confusion.
Message 9 of 10
(4,432 Views)
And computers don't work on paper. What's your point? Computers don't store numbers the way you write them on paper. That's a fact. It's been a fact since computers were invented. You, as the programmer need to understand this and deal with it, or just stick with a paper and pencil. The others here have tried to explain it and offered suggestions. Yet you insist that "school rounding" is the "correct" rounding. There is no correct rounding. There are simply rounding rules. Did you read the link Gerd pointed you to?
Message 10 of 10
(4,427 Views)
