How to retrieve a value from memory with pointer
I am attempting to use Labview to communicate with a PCI board (via DLL file) in order to control a CCD camera. When the board is initialized it returns a pointer. I need to access the handle for the board which is located at the memory location designated by the pointer. How can I, given that I know the pointer, find out the string that is stored in memory? Any help is appreciated.
Message 1 of 8
(4,690 Views)
You can create your own dll or cin to retrive the string.
Good luck.
George Zou
http://gtoolbox.yeah.net
George Zou
Message 2 of 8
(4,690 Views)
I had the exact same problem with a DLL only returning a pointer. I solved this by making a simple CIN, passed the pointer as an input together with number of bytes to read and returning a byte array. You probably have to manipulated this byte array to get the format you need.
I attach a VI with the simple CIN and also the source code for the CIN if you need to rebuild or modify it in any way.
Mattias Ericsson
Endevo Sweden
Message 3 of 8
(4,690 Views)
Do you need data, a value (handler) or a string from this pointer? If you
need data the following applies. Our do you want to get a handle to a string
at a pointer's adress?
You can use the Windows API "lstrcpyn" to retreive data from an adress. Make
the destination buffer large enough. The function copies the string until
/00 is encountered, and returns a pointer to the copied string, which LV
converts to a string. Get the size of the string. If it's shorter then the
expected length, it is truncted by a /00. Concatinate a /00 to the string,
and get the rest of the data from the pointer+stringlength+1. Repeat until
all data is in LabVIEW.
It's crude, but it works...
Wiebe.
"Mark Hageman" wrote in message
news:50650000000800000083
AA0000-1066448259000@exchange.ni.com...
Message 4 of 8
(4,690 Views)
The attached VI might work. I'm not able to test it very well right now...
Wiebe.
"Wiebe@CARYA" wrote in message
news:3f9e9bac@newsgroups....
> Hi,
string
Make
> Regards,
> Wiebe.
> news:50650000000800000083AA0000-1066448259000@exchange.ni.com...
[Attachment pointer to pointer.vi, see below]
Message 5 of 8
(4,690 Views)
Hi!
As far as I understand, incorrect value returned by your "pointer to pointer.vi".
Example for correct function in attachment.
with best regards
Message 6 of 8
(4,690 Views)
Perhaps the reversed string at the end in incorrect, I'm not sure about
it...
Wiebe.
"Andrey Dmitriev" wrote in message
news:50650000000500000089330100-1066448259000@exchange.ni.com...
> Hi!
> pointer.vi".
> with best regards
Message 7 of 8
(4,690 Views)
Browsing for a way to test things (sorry, don't use LV7 jet..) I found this
dll.
Wiebe
> Hi!
> pointer.vi".
> with best regards
[Attachment pointer.zip, see below]
Message 8 of 8
(4,690 Views)
