How to restrict boolean text size
Hi friends can any one knows the answer ........
(2,859 Views)
Hi LabView5,
at runtime the string length of the boolean text is either fixed (no changes possible by user) or you redefine the string by using property nodes - so you are in control of the stirng length...
(2,845 Views)
See i want the Boolean text length to 10 at runtime  is it  possible
(2,835 Views)
read the string from property node, use "string subset" with length=10, write back to property node.
Not sure what you want to achieve...
(2,833 Views)
