How to resize/move any window
I don't know if it is possible but is there a way to resize wondows on the monitor that don't belong to a LabVIEW VI? I know you can move windows to the front with windows API calls but is it possible to resize ot move them? I just want to be sure I'm not on a wild goose chase.
(6,452 Views)
Have you looked into .NET or ActiveX calls?
(6,395 Views)
Call Win32 dll with LabVIEW and use related function
I think there is function that you can resize windows
http://labview360.com/forum/forum_uploads/files/jimmychen/2004-03-19_153916_an088.pdf
(6,371 Views)
The WinAPI function SetWindowPos will do both:
https://msdn.microsoft.com/en-us/library/windows/desktop/ms633545(v=vs.85).aspx
You can use MoveWindow, too:
https://msdn.microsoft.com/en-us/library/windows/desktop/ms633534(v=vs.85).aspx
Use the FindWindow function to get the window handle you need above:
https://msdn.microsoft.com/en-us/library/windows/desktop/ms633499(v=vs.85).aspx
(6,367 Views)
Windows API Function Utilities (32-bit) for LabVIEW
http://www.ni.com/example/29935/en/
George Zou
(6,352 Views)
That's great news. I was able to get a VI up and running to move and resize windows and child windows. I ran into an issue trying to control windows on a remote desktop session. I assumed they would be child windows of the desktop session but that doesn’t seem to be the case. Does anyone have an idea or possible way to get window handles for windows in a remote desktop session?
(6,312 Views)
Accepted by topic author Brandon.Baxter
A remote desktop session is basically just showing you an image of what's going on, it's not a proper program with child windows.
If you want to control those windows, you'd have to write a server app on the remote PC that your LabVIEW program communicates with.  You would have to send the server a message to resize the window and have the remote program run the actual resize.
(6,304 Views)
