How to reset to default value every time I click abort execution?
Get into the habit of creating an initialization state where default values and appearances (show/hide, enable/disable etc) for various controls/indicators are set.
This state should be the first thing to run when your program starts (maybe after some hardware safety checks if you have those).  Since it is a stand alone state, it can be called whenever you want to (say after you abort a simulation mid-process).  I am using the term "abort" here rather loosely, not referring to the "ABORT EXECUTION" red stop-sign.
Message 11 of 14
(960 Views)
By "Stops" I mean that the execution state goes to 'Idle'.
Message 12 of 14
(947 Views)
@sunson29 wrote:
Hi Paul,
I tried your VI, thank your for that.  I think it reset after the program finished all process, right?   Btw, it was not working, I do put it one front panel. But it seems that vi will keep loading something if I abort the execution.  so that I have to wait for 3- 5 sec to run it again.
I don't observe that behavior.  It works fine for me.
To see where the action is look at the 'Exec State Change' case in the Facade.vi
Message 13 of 14
(947 Views)
Thank you!
Message 14 of 14
(944 Views)
