How to reset a square wave graph?
I am using a PID controller to monitor a setpoint pressure so I want to create a square wave graph that runs for 60 s at a value of 1 and then for 1s it runs at a value of 0.
I have created a formula node with the following code:
u1=0;
P1=0;
Reset=0;
if {(u1<= 59)
P1==1
else {
(u1>59)
P1==0
for (i=0 ; i<0.5 ; i++) ; //this section just gives a time delay of 0.5 s
reset==1
my formula node has an input value of u1 which stands for time and two outputs P1 (pressure) and reset which resets the graph to the above code continuously.
The image above shows what I have so far where I want to reset the code that is running in my program every time the 60 s interval is done (which should look like the graph below)
my amplitude is supposed to be my pressure P1 which runs for 59 s at amplitude of 1, and 1s at an amplitude of 0. I want to get this pattern continuously therefore that is why my code needs to be reset. Anyone know how I can do this?
(3,626 Views)
Your formula node do nothing.
u1=0;
P1=0;
Reset=0;
So, u1 input doesn't matter. u1 =0 any case.
if {(u1<= 59)
P1==1
and u1<59 averytime
so P1=1
else {
(u1>59)
P1==0
reset==1
and this part never work.
But even if u1>59
why you think that
"for (i=0 ; i<0.5 ; i++)  "
give you delay 0.5s?
There are always 1 iteration and stop (i++  = i+1 = 1 > 0.5)
(3,598 Views)
No formula node needed.  Just set the Elapsed Time VI to reset every 1 second and compare the elapsed time output to 0.5.  Then you know if you should have a high or low.
(3,587 Views)
