How to represent Enum control in Slide fashion
The Enum comes as a menu bar, but how if I want to represent it as a slide bar in which all options are visible and we can shift between them using the slide option.
Please guide me how to achieve this task.
Regards
(3,062 Views)
Accepted by topic author Abuzar
Turn the slide into an integer.  Enable text labels and sequential values and put in a label that matches your enum for each item one by one.  Now you can use that numeric value from the slide control wherever you would use the enum.
(3,040 Views)
Thanks a lot. With you help i was able to achieve this target, but a little problem is still remaining. I want the string output to be fetched in an array but this control is giving numeric output.
Is it some how possible to get a string output.
Regards
(2,982 Views)
Hi Abuzar,
use the slide's integer as an index to an array constant filled with your "string outputs"…
(2,979 Views)
