How to remove headers of a data save in excel?
Hi, I'm using the example Acq Graph & Cont to store the data from an experiment into a file excel.  I placed outside the loop  one block of export waveform to spreadsheet placing enable indexing to store the data throughout the experiment. How to remove the headers generated in the excel file for every second of acquisition?
Thank you
PS I am using Labview 6.0.1
(2,579 Views)
With the Export Waveforms to Spreadsheet File, do you not see the input called Header? do you read the help on what that does? Did you try setting that to False to see what change it makes in your file?
(2,572 Views)
