How to remove entries from the plot legend?
Jörn wrote:
Hi Suse,
thanks, yes, I had. I already implemented such a feature to select curves. But in my VI only the selected plots are arrayed and displayed (and not set to an empty array as in your example). This has got the  advantage, that if you are displaying e.g. curve 1, 14 and 15 the legend consist of three elements only and not of 16 elements as in your example.
It would be good to have a boolean property like "adjust display range" for arrays (I think the legend is based on an array) which automatically changes the top displayed element if the number of array elements is reduced so that the user always sees valid array elements. This property would be good for Listboxes as well.
Is that worth to be put on the wish list for future releases of LabView?
Regards, Jörn
Better would be a simple property Legend:TopIndex
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 11 of 12
(2,147 Views)
Good morning,
yes you can write a product suggestion on the following page: http://digital.ni.com/applications/psc.nsf/default?OpenForm
But I inform you about the fact that I can't say when the suggestion would be implemented! Usually in one of the next upgrades of LabVIEW.
Can you use meanwhile the example I sent to you or should we search for anaother solution which is better for you?
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
Message 12 of 12
(2,136 Views)
