How to reinitialize a stopped while loop
I couldn't view Paul's, but I think the pause/resume is probably the best way to go (as the loop can respond to different messages when not running the timeout code). Here is a version using an event structure just for fun.
Message 11 of 14
(1,711 Views)
No need to get so complicated.
(anybody spot the bug in the vi in my earler post?)
Message 12 of 14
(1,697 Views)
Hello paul_cardinale,
A problem appears with your VI. The isn't stop right away, as event structure buffered event, it take several iteration before pausing.
However, it's a good idea.
regards.
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
Message 13 of 14
(1,654 Views)
Hi Jatlauoi,
It depends how you define right away. If you press pause when i=0, that will trigger an event and update i=1, it will then start the next loop and update i=2 but be waiting on the event structure before making another move. The only loop cycle used up by flipping the switch is i=1, so I would say that it stops right away.
Message 14 of 14
(1,622 Views)
