Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
03-30-2020
05:19 PM
- last edited on
10-19-2025
04:20 PM
by
Content Cleaner
I am referencing the following NI tutorial:
http://www.ni.com/tutorial/53682/en/
On the server application side, I am confused on how the FIFO refnum cluster is being created and then unbundled to retrieve the proper FIFO refnum. Below is the direct link to the server application block diagram in question.
I would like to implement something similar to select the right FIFO refnum by a descriptive name. What is going on inside the Init RT FIFO, Close RT FIFO, Read, and Write FIFO subVIs in this tutorial?
Thank you.
Solved! Go to Solution.
04-02-2020 02:40 PM
That example is intended for LabVIEW Real-Time. Maybe I did not get the question but is this helpful?:
You need to wire the type first with the desired data type and then right click on rt fifo refnum output and create constant or control. You can then copy the constant/control and paste it on your FIFO Refnum Cluster.
04-02-2020 03:01 PM
Thanks LucianM. Yes, this was the root of my question. I was incorrectly creating the FIFO refnum constant before (and not after) wiring the desired data type for each individual FIFO, which in my case were all unique data types..
