How to read time from file onto X axis
I've read multiple posts on time stamping the X axis, but none have satisfactorily answered how to read a file that has a date/time and place it on the X axis in correspondence to the data points.  The data/time is not the current time, but the time from previous data collection. I am going nuts trying figure out how to do this, it seems like it should be simple, yet there is no apparent way to do this. Anybody know how this can be done?
Message 1 of 13
(5,027 Views)
Are you using a graph, chart or x-y graph? It makes a difference. Is your time stamp a string or floating point number? Can you post an example file?
Message 2 of 13
(5,021 Views)
Thank you for the response. I will use whatever works, but usually I use a graph.  Here is the file, all I want to do is put the time (first column) on the X-axis and the second column (my variable) on the Y-Axis.
Message 3 of 13
(5,009 Views)
You have to convert time stamps to a double time value (Seconds since ???) and your data to numbers (String to number) Doubles . A graph /chart has a T0 (Initial time ) Delta T (Time between samples) It looks like your Delta T is 1 second.
There may be a tool to convert text or delimited files to a tdms file format. TDMS is the National Instruments best method to save and view chart data. You should use some of the on line examples to see example code and use.
Message 4 of 13
(4,989 Views)
Something like that...
All your points have 1 second spacing, so I recommend waveform. twice less data in memory.
File is pretty large, it is better to read one line at a time, but data conversion is below.
Message 5 of 13
(4,970 Views)
I would suggest a waveform as well but if your sampling changes, you should calculate the dt from the file as well.
Message 6 of 13
(4,951 Views)
wow you guys this gets deep quick... I thought it would be much simpler. Not sure what many of those functions even are on that template.
Message 7 of 13
(4,936 Views)
There's nothing there except Index Array and Scan From String. The image is a snippet so all that you have to do is save the file and then drag it to a block diagram. Instant VI that you can run and use with Context Help turned on.
Message 8 of 13
(4,913 Views)
Oh I was unaware that the snipit could be used actively on the VI.  It doesn't appear to be able to be saved in labview, it just saves as an image. Also, I am running Labview 8.5, so maybe that is part of the reason I can never view nor use the sample templates on these threads.
Message 9 of 13
(4,893 Views)
yes, 8.5 does not support snippets.
this can help (did not try it though)
https://lavag.org/files/file/118-getsnippet/
original snippet as vi is in attachment
Message 10 of 13
(4,863 Views)
