How to read text in variant input terminal on control pane
Hi all,
I've created a 3D array of double and I've sent it to sub vi to a variant terminal. How to read info that is displayed on the terminal? The message on the terminal that I want to read is:
'': 3D array of
'': double [64-bit real (~15 digit precision)]
[500x5x0]
I'd be grateful for any help!
Pete
Message 1 of 11
(4,919 Views)
You could just use the Variant To Data with a 3D Array wired to the data type to get your array back.  Granted, at that point you might as well not have used the variant.
Message 2 of 11
(4,906 Views)
You can't read that text that appears in the control directly, but you can reconstruct it. Why do you need the text?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 11
(4,880 Views)
@Piotr.Zawistowski wrote:
Hi all,
'': 3D array of
[500x5x0]
Pete
I don't know what you might expect from an array which have 0 column, it will never contain any value.
The VariantType.lvlib:GetArrayInfo.vi can also give you informations (number of dimensions, element data type).
To retrieve the original array use the Variant To Data function as specified by Crossrulz.
Ben64
Message 4 of 11
(4,850 Views)
Hi all,
thanks for replying. I just want to have generic terminal to which I can connect any type of data and, using this information from the terminal, change to proper type. I can easily get the information that this is a cluster but how about any information about dimensions and type of data...? Any clue?
Message 5 of 11
(4,814 Views)
As I said, have a look at the vis inside the VariantType.lvlib. There is a vi called GetClusterInfo.vi
You can find this library at the following location:
C:\Program Files (x86)\National Instruments\LabVIEW 2014\vi.lib\Utility\VariantDataType
Alternately you can download the "Hidden Gems in vi.lib" package from the JKI VI Package Manager.
Ben64
Message 6 of 11
(4,800 Views)
When you say "any", do you really mean ANY datatype. If the expected data types are somewhat constrained, a polymorphic VI might be an easier way to get where you're going.
Mike...
LabVIEW Champion
Message 7 of 11
(4,798 Views)
Maybe not any, but arrays, doubles, integers, strings, etc.. I want to create XML file later.
Message 8 of 11
(4,789 Views)
Well you can flatten a variant directly to XML.
Mike...
LabVIEW Champion
Message 9 of 11
(4,779 Views)
But in the array case, I'd rather like to get dimensions and size of it, rather then log data to XML (for performance reasons). I thought it's easier if the information I need, is displayed on terminal...
Message 10 of 11
(4,751 Views)
