How to read multiple cursor values of a graph
I have a graph that I am trying to read the X values of two cursors that are moveable. I have found that you can create a property node of the graph and read the X value of one cursor, but I need the X value of both. I was thinking it had something to do with the cursor index, but got stuck after that.
So basically all I need is to be able to move one cursor on the X axis and get that value, and move another cursor on the X axis and get that value. I am currently using the indicator box and manually reading the data, but would like for it to be automated.
Thanks!
Message Edited by Derrick M on 02-18-2010 09:53 AM
(3,552 Views)
Try out the 'Active Cursor' property.
(3,539 Views)
This only half works for me.  I would like to be able to get both indices at the same time for dynamic plotting of curves and their differences.
(2,440 Views)
Set the active cursor to the first one.  Read the X.
Set the active cursor to the second one.  Read the X.
It can be done in one property node.
TDMS%20Viewer_BD
(2,431 Views)
