How to read data through different device IPs in LabVIEW
I am reading data successfully to the port (say 6342) from the local host. But I am facing problems when I try to read the data on the same port from different IP. I am using "TCP Listen.vi".
(2,550 Views)
Hi Hasan,
can you give some more information please or maybe post your vi? Where do you have problems? Can you build a connection between the pcs?
Mike
(2,534 Views)
I meant to say that TCP Listen.vi was working when I try to communicate on the same LAN but it was not when the machine having IP from other network  try to ommunicate. Well the problem has been diagnosed.
thanks for response.
(2,513 Views)
