How to read data from different column using Subset Array
Hi..
I would like to read data from different column. I have three columns. Two columns are next to each other but the other column is not. I used to the subset array to extract the data out but I am having problem in extracting the data from the separated column (which is not next to the two columns). File attached, please help.
Many thanks.
(3,073 Views)
here you go (attached file). You have to remember, you're trying to add a single array to a 2D array. (If you try to do it with two 2D arrays it doesn't work - they'll concatenate.
I'd suggest avoiding the Subset array .vi for this application - use either the delete from array to remove the unwanted columns, or index array to build up a set of 1D arrays that you can build together and transpose.
Hope that helps
S.
// it takes almost no time to rate an answer Smiley Wink
(3,073 Views)
