How to read data from a excel and HTML file
Hi
    I am writing an 2D-array of string into Excel/HTML file using Report generation.
    Can anybody tell me how to retrieve back the written data from the same files again and view in array format.
Thanks & regards
Visuman
Message 1 of 9
(5,212 Views)
Accepted by topic author visuman
you can use activex to read the data from the excel fileback in the array format...go through this vi...may b this will help you.........
Message 2 of 9
(5,205 Views)
there are also very good examples of reading from excel in the example's that ship with labview
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 3 of 9
(5,198 Views)
also this may help with the HTML:
http://sine.ni.com/devzone/cda/epd/p/id/1924
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 4 of 9
(5,195 Views)
thanks shruthi its working.
Message 5 of 9
(5,189 Views)
you are welcome....mark it as a solution if it solve ur problem...
Message 6 of 9
(5,161 Views)
Hi
Currently the code will read the data from range Cell 1 to Cell 2. Is there any option to read entire data completely its because the cell values will change each time. I would like to make it as automated i.e reading the whole content of the file and giving the result in array.
Thanks & Regards
Visuman
Message 7 of 9
(5,153 Views)
Use the modified Read Excel VI.
-Kumar.B
Message 8 of 9
(5,139 Views)
For HTML read see this link.
-Kumar.B
Message 9 of 9
(5,127 Views)
