How to read cells in excel sheet while run time
   Anyone have solution for my problem plz provide me ASAP.
Actually I want to open excel sheet,visible to user, from that excel sheet i need to select rows & columns,then stored into table in lab view.
IAnd one more thing then close the excel sheet.
Thanks & Regards
Anitha
Message 1 of 19
(4,831 Views)
Hi Anitha,
this should help you http://zone.ni.com/devzone/cda/epd/p/id/2231
Mike
Message 2 of 19
(4,826 Views)
Hi Mike,
   In this example defined the range;but i don't want like that.
For example first step open the excel sheet,visible to user,through hand i need to select from opened excel sheet,and stored into labview,then close the file.
Thanks & Regards
Anitha
Message 3 of 19
(4,822 Views)
Hi Anitha,
if i understand you correct you want that the user select the Data stored in LabView manually, right? For that you can define a Callback function.
Mike
Message 4 of 19
(4,819 Views)
Hi Mike,
  Yes ur right.How to do callback function,can you plz explain little bit clear.
Thanks & Regards
Anitha
Message 5 of 19
(4,815 Views)
Hi Anitha,
there is a function to define callback functions in the ActiveX part of LabView. An example is available in the example finder. Search for callback. One of the examples is with Excel.
Mike
Message 6 of 19
(4,814 Views)
Hi Mike,
  I don't want this way.For example in my excel sheet sunday,monday.....friday are stored in first colum.
Now in labview i opend that file with mouse i will place on sunday then that sunday automatically stored into labview .like that all one by one or all i need to store.
Thanks & Regards.
Anitha
Message 7 of 19
(4,809 Views)
I'm sorry, but there's clearly a language issue here. What do you mean "automatically stored in LabVIEW"? Is it supposed to go into a table, a string indicator, a variable, ... ? Also, what does "like that all one by one or all i need to store" mean? Do you mean that if someone clicks on an individual cell then that cell's contents should be transferred to LabVIEW, or if the user selects a range then that range should be transferred to LabVIEW, or neither, or both?
Message 8 of 19
(4,800 Views)
Hi Mike,
    If user clicks on an individual cell then that cell's contents should be transferred to LabVIEW & stored (table/string indicator/ variableor)& also if the user selects a range then that range should be transferred to LabVIEW.Both way I need.
Thanks & Regards
Anitha
Message 9 of 19
(4,792 Views)
Hi Anitha,
i understand what you mean. Here is an example with the callback you need. To test it, create a new workbook or open an existing one and click into the cells.
Mike
Message Edited by MikeS81 on 04-03-2008 04:15 PM
Message 10 of 19
(4,789 Views)
